PARTICLES SCRIPTS - Форум
  • Страница 1 из 1
  • 1
Модератор форума: terex
PARTICLES SCRIPTS
terexДата: Воскресенье, 13.03.2011, 01:45 | Сообщение # 1
Zzz
Группа: Администраторы
Награды: 1
Статус: Offline
скрип разбиение стекла С#
Code
using UnityEngine;
using System.Collections;
using System;
/// <summary>
/// Type of glass.
/// </summary>
public enum GlassType
SINGLE,
DIVIDED,
/// <summary>
/// </summary>
public class GlassScript : MonoBehaviour
#region Public Data
//Glass type.
public GlassType glassType;
//Number of point in matrix.
public int tileHorizontal;
public int tileVertical;
//Prefab of particle object emmited when break the glass.
public GameObject particlePrefab;
//Breaked texture (when hit the first time).
public Texture2D textureBreaked;
//Texture with base marks.
public Texture2D[] textureBaseMarks;
//Max number bullets to break all glass.
public int maxNumberToBreak;
#endregion
#region Internal Data
//Used to change mainTexture when happen the first hit.
private bool firstHit;
//Size of alpha texture.
private int sizeTextureX;
private int sizeTextureY;
//The base size of a simple "broked" square of glass alpha texture.
private int baseQuadSizeX;
private int baseQuadSizeY;
//Need a simple texture "isReadable", to set later with SetPixels.
private Texture2D textureCurrentAlpha;
//Record all squares of matrix, true if is broken, false if isnt broken yet.
private bool[,] matrixOfGlass;
private int[,] selectedMarkNumber;
//Aux transform to place in position of bullet when it collide with glass.
private GameObject objectColliding;
//Structs of data glass marks.
private GlassStruct[] glassStruct;
//Instance of textureBaseMarks.
private Texture2D instanceTextBaseMarks;
//Particle emmiter on center of each point of glass.
private ParticleEmitter[,] matrixEmmiters;
//Number of breaked points.
private int numberToBreak;
//TODO DELETE
private Cubemap cubeMap;
private AudioClip destructAudio;
private AudioClip hitAudio;
private bool playDestruction;
#endregion
private float auxHorizontal;
private float auxVertical;
private Transform parentEmmiters;
/// <summary>
/// </summary>
void Start()
playDestruction = true;
//Warning.
if (tileHorizontal % 2 != 0 || tileVertical % 2 != 0)
Debug.LogWarning("Use power of 2 tile horizontal and vertical!");
destructAudio = GameSoundManager.GetClip("glass_destruction");
hitAudio = GameSoundManager.GetClip("glass_hit");
if(audio == null)
gameObject.AddComponent<AudioSource>();
audio.loop = false;
audio.playOnAwake = false;
//Intialize with false the first hit (used to change texture to breaked).
firstHit = false;
//Set base alpha texture size.
sizeTextureX = (int)((textureBaseMarks[0].width / 4.0f) * tileHorizontal);
sizeTextureY = (int)((textureBaseMarks[0].height / 4.0f) * tileVertical);
textureCurrentAlpha = new Texture2D(2, 2, TextureFormat.ARGB32, true);//(Texture2D)renderer.material.GetTexture("_AlphaTex");
renderer.material.SetTexture("_AlphaTex", textureCurrentAlpha);
//Resize the base alpha color of glass.
textureCurrentAlpha.Resize(sizeTextureX, sizeTextureY);
//Set all glass with white color and apply.
Color[] auxTexColors = new Color[(int)(textureCurrentAlpha.width * textureCurrentAlpha.height)];
for (int i = 0; i < auxTexColors.Length; i++)
auxTexColors[i] = Color.white;
textureCurrentAlpha.SetPixels(0, 0, textureCurrentAlpha.width, textureCurrentAlpha.height, auxTexColors);
textureCurrentAlpha.Apply();
//Create the glass matrix.
matrixOfGlass = new bool[tileHorizontal + 2, tileVertical + 2];
selectedMarkNumber = new int[tileHorizontal + 2, tileVertical + 2];
for (int i = 0; i < matrixOfGlass.GetLength(0); i++)
for (int j = 0; j < matrixOfGlass.GetLength(1); j++)
matrixOfGlass[i, j] = false;
selectedMarkNumber[i, j] = -1;
//Create object that simulate colliding bullet.
objectColliding = new GameObject("object_colliding");
objectColliding.transform.parent = transform;
objectColliding.transform.localPosition = Vector3.zero;
//Calculate the size of one recorte base alpha texture.
baseQuadSizeX = (int)(textureBaseMarks[0].width * 0.25f);
baseQuadSizeY = (int)(textureBaseMarks[0].height * 0.25f);
//Start all marks squares.
glassStruct = new GlassStruct[16];
for (int i = 0; i < 4; i++)
for(int j = 0; j < 4; j++)
glassStruct[(i * 4) + j] = new GlassStruct((i * 4) + j,
new GlassMark(textureBaseMarks[0].GetPixels(i * baseQuadSizeX, j * baseQuadSizeY, baseQuadSizeX, baseQuadSizeY)),
new GlassMark(textureBaseMarks[1].GetPixels
(i * baseQuadSizeX, j * baseQuadSizeY, baseQuadSizeX, baseQuadSizeY)));
//Create a basic black square to fill intersections of four breaked points.
GlassStruct.blackFillTexture = new Color[baseQuadSizeX * baseQuadSizeY];
for (int i = 0; i < baseQuadSizeX; i++)
for (int j = 0; j < baseQuadSizeY; j++)
GlassStruct.blackFillTexture[(i * baseQuadSizeX) + j] = Color.black;
//Set base marks with sides (left side, top side, right side, bottom side) -> True if breaked, False if not breaked.
glassStruct[0].SetSides(true, false, true, true);
glassStruct[1].SetSides(false, true, true, false);
glassStruct[2].SetSides(false, true, false, false);
glassStruct[3].SetSides(false, false, false, false);
glassStruct[4].SetSides(true, true, false, true);
glassStruct[5].SetSides(false, false, true, true);
glassStruct[6].SetSides(true, false, true, false);
glassStruct[7].SetSides(true, false, false, false);
glassStruct[8].SetSides(true, true, true, false);
glassStruct[9].SetSides(true, false, false, true);
glassStruct[10].SetSides(false, true, false, true);
glassStruct[11].SetSides(false, false, true, false);
glassStruct[12].SetSides(true, true, true, true);
glassStruct[13].SetSides(false, true, true, true);
glassStruct[14].SetSides(true, true, false, false);
glassStruct[15].SetSides(false, false, false, true);
//Create particle system.
parentEmmiters = new GameObject("particle_emmiters").transform;
parentEmmiters.parent = transform;
parentEmmiters.localPosition = Vector3.zero;
parentEmmiters.rotation = transform.rotation;
parentEmmiters.localScale = Vector3.one;
matrixEmmiters = new ParticleEmitter[tileHorizontal, tileVertical];
auxHorizontal = 10f / (float)tileHorizontal;
auxVertical = 10f / (float)tileVertical;
for (int i = 0; i < tileHorizontal; i++)
for (int j = 0; j < tileVertical; j++)
//Crate emmiters and set position.
matrixEmmiters[i, j] = ((GameObject)GameObject.Instantiate(particlePrefab, Vector3.zero, Quaternion.identity)).GetComponent<ParticleEmitter>();
matrixEmmiters[i, j].name = string.Format("emmiter{0}{1}", i, j);
matrixEmmiters[i, j].transform.parent = parentEmmiters;
matrixEmmiters[i, j].transform.forward = parentEmmiters.forward;
matrixEmmiters[i, j].transform.localPosition = new Vector3((auxHorizontal * (tileHorizontal - i - 1)) + (auxHorizontal * 0.5f) - 5f, 0.0f, (auxVertical * (tileVertical - j - 1)) + (auxVertical * 0.5f) - 5f);
matrixEmmiters[i, j].gameObject.active = false;
//Initialize number of break points with 0.
numberToBreak = 0;
/// <summary>
/// </summary>
public void Hit(RaycastHit p_hit)
Vector3 p_point = p_hit.point;
//If is the first hit, change the mainTexture to breaked.
if (firstHit == false && glassType == GlassType.SINGLE)
renderer.material.SetTexture("_MainTex", textureBreaked);
firstHit = true;
//Translate aux transform to position of hit with glass collision.
objectColliding.transform.position = p_point;
objectColliding.transform.localPosition = new Vector3(objectColliding.transform.localPosition.x, objectColliding.transform.localPosition.y, objectColliding.transform.localPosition.z);
//Calculate relative value of hit position (0 - 1).
Vector2 hitPosition = new Vector2(Mathf.Abs(objectColliding.transform.localPosition.x - 5) * 0.1f, Mathf.Abs(objectColliding.transform.localPosition.z - 5) * 0.1f);
//Select position on alpha texture to SetPixels.
int posX = (int)(hitPosition.x * tileHorizontal) * (textureCurrentAlpha.width / tileHorizontal);
int posY = (int)(hitPosition.y * tileVertical) * (textureCurrentAlpha.height / tileVertical);
//Position X and Y in matrix (Ex: 0, 1, 2..)
int matrixX = Mathf.Min((posX / baseQuadSizeX) + 1, tileHorizontal);
int matrixY = Mathf.Min((posY / baseQuadSizeY) + 1, tileVertical);
bool oldBreak = matrixOfGlass[matrixX, matrixY];
//Break a point.
BreakAPoint(matrixX, matrixY);
if (oldBreak == false && glassType == GlassType.SINGLE)
//Test if will break all glass.
TestBreakAll();
//Random Breaks.
RandomBreak(matrixX, matrixY);
//Test if gravity will break the glass.
TestGravityBreak();
//Apply all current changes in the alpha texture.
/// <summary>
/// Break a point on glass (fill the alpha texture with mark of breaked).
/// </summary>
void BreakAPoint(int p_matrixX, int p_matrixY)
p_matrixX = Mathf.Min(p_matrixX, tileHorizontal);
p_matrixY = Mathf.Min(p_matrixY, tileVertical);
//If this hitted point is breaked, return.
if (matrixOfGlass[p_matrixX, p_matrixY] == true)
return;
if(hitAudio != null)
audio.PlayOneShot(hitAudio);
//Set in matrix true in element that received hit.
matrixOfGlass[p_matrixX, p_matrixY] = true;
selectedMarkNumber[p_matrixX, p_matrixY] = UnityEngine.Random.Range(0, textureBaseMarks.Length);
//Emit particles.
if(p_matrixX - 1 >= 0 && p_matrixY - 1 >= 0 && p_matrixX - 1 < tileHorizontal && p_matrixY - 1 < tileVertical)
if(matrixEmmiters[p_matrixX - 1, p_matrixY - 1] == null)
matrixEmmiters[p_matrixX - 1, p_matrixY - 1] = ((GameObject)GameObject.Instantiate(particlePrefab, Vector3.zero, Quaternion.identity)).GetComponent<ParticleEmitter>();
matrixEmmiters[p_matrixX - 1, p_matrixY - 1].name = string.Format("emmiter{0}{1}", p_matrixX - 1, p_matrixY - 1);
matrixEmmiters[p_matrixX - 1, p_matrixY - 1].transform.parent = parentEmmiters;
matrixEmmiters[p_matrixX - 1, p_matrixY - 1].transform.forward = parentEmmiters.forward;
matrixEmmiters[p_matrixX - 1, p_matrixY - 1].transform.localPosition = new Vector3((auxHorizontal * (tileHorizontal - p_matrixX)) + (auxHorizontal * 0.5f) - 5f, 0.0f, (auxVertical * (tileVertical - p_matrixY)) + (auxVertical * 0.5f) - 5f);//new Vector3((auxHorizontal * (tileHorizontal - p_matrixX - 2)) + (auxHorizontal * 0.5f) - 5f, 0.0f, (auxVertical * (tileVertical - p_matrixY - 2)) + (auxVertical * 0.5f) - 5f);
matrixEmmiters[p_matrixX - 1, p_matrixY - 1].Emit();
//Set hitted mark.
int number = SelectMarkNumber(p_matrixX, p_matrixY);
if (number != -1) textureCurrentAlpha.SetPixels((p_matrixX - 1) * baseQuadSizeX, (p_matrixY - 1) * baseQuadSizeY, baseQuadSizeX, baseQuadSizeY, glassStruct[number].GetColorMark(selectedMarkNumber[p_matrixX, p_matrixY]));
//If type is SINGLE, test sides.
if (glassType == GlassType.SINGLE)
//Test side points.
TestSidePoints(p_matrixX, p_matrixY);
//Test intersection points.
TestIntersectionPoints(p_matrixX, p_matrixY);
/// <summary>
/// If left, top, right, bottom marks is true, change marks too.
/// </summary>
private void TestSidePoints(int p_matrixX, int p_matrixY)
int p_posX = (p_matrixX - 1) * baseQuadSizeX;
int p_posY = (p_matrixY - 1) * baseQuadSizeY;
//Record old color to multiply by new changed side mark (because no override intersections).
Color[] oldColor = new Color[baseQuadSizeX * baseQuadSizeY];
Color[] newColor = new Color[baseQuadSizeX * baseQuadSizeY];
//Left point.
if (matrixOfGlass[p_matrixX - 1, p_matrixY] == true)
int numberLeft = SelectMarkNumber(p_matrixX - 1, p_matrixY);
oldColor = textureCurrentAlpha.GetPixels(p_posX - baseQuadSizeX, p_posY, baseQuadSizeX, baseQuadSizeY);
MultiplyColorArrays(glassStruct[numberLeft].GetColorMark(selectedMarkNumber[p_matrixX - 1, p_matrixY]), oldColor, ref newColor);
if (numberLeft != -1) textureCurrentAlpha.SetPixels(p_posX - baseQuadSizeX, p_posY, baseQuadSizeX, baseQuadSizeY, newColor);
//Top point.
if (matrixOfGlass[p_matrixX, p_matrixY + 1] == true)
int numberTop = SelectMarkNumber(p_matrixX, p_matrixY + 1);
oldColor = textureCurrentAlpha.GetPixels(p_posX, p_posY + baseQuadSizeY, baseQuadSizeX, baseQuadSizeY);
MultiplyColorArrays(glassStruct[numberTop].GetColorMark(selectedMarkNumber[p_matrixX, p_matrixY + 1]), oldColor, ref newColor);
if (numberTop != -1) textureCurrentAlpha.SetPixels(p_posX, p_posY + baseQuadSizeY, baseQuadSizeX, baseQuadSizeY, newColor);
//Right point.
if (matrixOfGlass[p_matrixX + 1, p_matrixY] == true)
int numberRight = SelectMarkNumber(p_matrixX + 1, p_matrixY);
oldColor = textureCurrentAlpha.GetPixels(p_posX + baseQuadSizeX, p_posY, baseQuadSizeX, baseQuadSizeY);
MultiplyColorArrays(glassStruct[numberRight].GetColorMark(selectedMarkNumber[p_matrixX + 1, p_matrixY]), oldColor, ref newColor);
if (numberRight != -1) textureCurrentAlpha.SetPixels(p_posX + baseQuadSizeX, p_posY, baseQuadSizeX, baseQuadSizeY, newColor);
//Bottom point.
if (matrixOfGlass[p_matrixX, p_matrixY - 1] == true)
int numberBottom = SelectMarkNumber(p_matrixX, p_matrixY - 1);
oldColor = textureCurrentAlpha.GetPixels(p_posX, p_posY - baseQuadSizeY, baseQuadSizeX, baseQuadSizeY);
MultiplyColorArrays(glassStruct[numberBottom].GetColorMark(selectedMarkNumber[p_matrixX, p_matrixY - 1]), oldColor, ref newColor);
if (numberBottom != -1) textureCurrentAlpha.SetPixels(p_posX, p_posY - baseQuadSizeY, baseQuadSizeX, baseQuadSizeY, newColor);
/// <summary>
/// Use to multiply each by each Color of array of Colors.
/// </summary>
private void MultiplyColorArrays(Color[] p_color1, Color[] p_color2, ref Color[] p_resultColor)
for (int i = 0; i < p_resultColor.Length; i++)
p_resultColor[i] = p_color1[i] * p_color2[i];
/// <summary>
/// If three intesection points is true, mark with black box.
/// </summary>
private void TestIntersectionPoints(int p_matrixX, int p_matrixY)
//Left / top three points.
if (matrixOfGlass[p_matrixX - 1, p_matrixY] == true && matrixOfGlass[p_matrixX - 1, p_matrixY + 1] == true && matrixOfGlass[p_matrixX, p_matrixY + 1] == true)
textureCurrentAlpha.SetPixels(p_posX - (int)(baseQuadSizeX * 0.5f), p_posY + (int)(baseQuadSizeY * 0.5f), baseQuadSizeX, baseQuadSizeY, GlassStruct.blackFillTexture);
//Right / top three points.
if (matrixOfGlass[p_matrixX, p_matrixY + 1] == true && matrixOfGlass[p_matrixX + 1, p_matrixY + 1] == true && matrixOfGlass[p_matrixX + 1, p_matrixY] == true)
textureCurrentAlpha.SetPixels(p_posX + (int)(baseQuadSizeX * 0.5f), p_posY + (int)(baseQuadSizeY * 0.5f), baseQuadSizeX, baseQuadSizeY, GlassStruct.blackFillTexture);
//Right / bottom three points.
if (matrixOfGlass[p_matrixX + 1, p_matrixY] == true && matrixOfGlass[p_matrixX + 1, p_matrixY - 1] == true && matrixOfGlass[p_matrixX, p_matrixY - 1] == true)
textureCurrentAlpha.SetPixels(p_posX + (int)(baseQuadSizeX * 0.5f), p_posY - (int)(baseQuadSizeY * 0.5f), baseQuadSizeX, baseQuadSizeY, GlassStruct.blackFillTexture);
//Left / bottom three points.
if (matrixOfGlass[p_matrixX, p_matrixY - 1] == true && matrixOfGlass[p_matrixX - 1, p_matrixY - 1] == true && matrixOfGlass[p_matrixX - 1, p_matrixY] == true)
textureCurrentAlpha.SetPixels(p_posX - (int)(baseQuadSizeX * 0.5f), p_posY - (int)(baseQuadSizeY * 0.5f), baseQuadSizeX, baseQuadSizeY, GlassStruct.blackFillTexture);
/// <summary>
/// Test if sides is broken and return the number of correct mark.
/// </summary>
private int SelectMarkNumber(int p_matrixX, int p_matrixY)
//Test if SINGLE, calculate side points and choose the correct mark.
//Get if sides is breaked or not.
bool left = matrixOfGlass[p_matrixX - 1, p_matrixY];
bool top = matrixOfGlass[p_matrixX, p_matrixY + 1];
bool right = matrixOfGlass[p_matrixX + 1, p_matrixY];
bool bottom = matrixOfGlass[p_matrixX, p_matrixY - 1];
int number = -1;
//Test all marks to get the correct mark depending of four sides marks (left, top, right, bottom), and return the correct Color[] mark.
for (int j = 0; j < 4; j++)
number = glassStruct[(i * 4) + j].IsThisMark(left, top, right, bottom);
if (number != -1)
return number;
//If dont returned yet, have error.
return 3;
//If DIVIDED, return 3 (single mark).
else
return 3;
/// <summary>
/// Random break 2 and 3 points above.
/// </summary>
void RandomBreak(int p_matrixX, int p_matrixY)
//Random try break above 2 or 3 points.
if (p_matrixY < 4)
int numberRandom = UnityEngine.Random.Range(0, 4);
//Break more one point above (25% chance).
if (numberRandom == 0)
BreakAPoint(p_matrixX, p_matrixY + 1);
//Break more two points above (25% chance).
else if (numberRandom == 1)
//Test if will break above of glass matrix.
if (p_matrixY < tileVertical - 1)
BreakAPoint(p_matrixX, p_matrixY + 2);
//If is base line, try to break sides.
if (p_matrixY == 1)
//33% chance break side point.
if (UnityEngine.Random.Range(0, 3) == 0)
//50% chance break left side.
if (UnityEngine.Random.Range(0, 2) == 0)
//If not matrix aux point 0, 0.
if (p_matrixX - 1 > 0)
BreakAPoint(p_matrixX - 1, p_matrixY);
else
BreakAPoint(p_matrixX + 1, p_matrixY);
else
//If not matrix aux point tileHorizontal + 1, 0.
if (p_matrixX < tileHorizontal)
else
/// <summary>
/// </summary>
public void BreakAll()
if(!firstHit)
firstHit = true;
if(destructAudio != null)
if(playDestruction)
playDestruction = false;
if(GlassManager.timeToPlayAudio <= 0.0f)
GlassManager.timeToPlayAudio = destructAudio.length;
audio.PlayOneShot(destructAudio);
//Set all point to true.
for (int i = 1; i < tileHorizontal + 1; i++)
for (int j = 1; j < tileVertical + 1; j++)
//Emmit particles.
if (matrixOfGlass[i, j] == false)
if(matrixEmmiters[i - 1, j - 1] == null)
matrixEmmiters[i - 1, j - 1] = ((GameObject)GameObject.Instantiate(particlePrefab, Vector3.zero, Quaternion.identity)).GetComponent<ParticleEmitter>();
matrixEmmiters[i - 1, j - 1].name = string.Format("emmiter{0}{1}", i - 1, j - 1);
matrixEmmiters[i - 1, j - 1].transform.parent = parentEmmiters;
matrixEmmiters[i - 1, j - 1].transform.forward = parentEmmiters.forward;
matrixEmmiters[i - 1, j - 1].transform.localPosition = new Vector3((auxHorizontal * (tileHorizontal - i)) + (auxHorizontal * 0.5f) - 5f, 0.0f, (auxVertical * (tileVertical - j)) + (auxVertical * 0.5f) - 5f);//new Vector3((auxHorizontal * (tileHorizontal - i - 2)) + (auxHorizontal * 0.5f) - 5f, 0.0f, (auxVertical * (tileVertical - j - 2)) + (auxVertical * 0.5f) - 5f);
matrixEmmiters[i - 1, j - 1].Emit();
matrixOfGlass[i, j] = true;
//Mark correct mark to points.
int num = SelectMarkNumber(i, j);
textureCurrentAlpha.SetPixels((i - 1) * baseQuadSizeX, (j - 1) * baseQuadSizeY, baseQuadSizeX, baseQuadSizeY, glassStruct[num].GetColorMark(UnityEngine.Random.Range(0, textureBaseMarks.Length)));
//Set all black intersections.
for (int i = 0; i < tileHorizontal - 1; i++)
for (int j = 0; j < tileVertical - 1; j++)
textureCurrentAlpha.SetPixels(i * baseQuadSizeX + (int)(baseQuadSizeX * 0.5f), j * baseQuadSizeY + (int)(baseQuadSizeY * 0.5f), baseQuadSizeX, baseQuadSizeY, GlassStruct.blackFillTexture);
enabled = false;
/// <summary>
/// Test if need break all glass.
/// </summary>
void TestBreakAll()
//Sum and test if break all glass.
numberToBreak++;
if (numberToBreak > maxNumberToBreak)
//Emmit particles.
matrixEmmiters[i - 1, j - 1].transform.localPosition = new Vector3((auxHorizontal * (tileHorizontal - i)) + (auxHorizontal * 0.5f) - 5f, 0.0f, (auxVertical * (tileVertical - j)) + (auxVertical * 0.5f) - 5f);//new Vector3((auxHorizontal * (tileHorizontal - i - 2)) + (auxHorizontal * 0.5f) - 5f, 0.0f, (auxVertical * (tileVertical - j - 2)) + (auxVertical * 0.5f) - 5f);//new Vector3((auxHorizontal * (tileHorizontal - i - 2)) + (auxHorizontal * 0.5f) - 5f, 0.0f, (auxVertical * (tileVertical - j - 2)) + (auxVertical * 0.5f) - 5f);
enabled = false;
return;
/// <summary>
/// Test if gravity will break the points of glass.
/// </summary>
void TestGravityBreak ()
//Base size of glass to break by gravity (only center points).
if (tileHorizontal > 4 && tileVertical > 2)
//Only center pieces.
for (int i = 2; i < tileHorizontal; i++)
for (int j = tileVertical - 1; j > 1; j--)
//Test1 (only one in center or only on side).
if (matrixOfGlass[i, j + 1] && matrixOfGlass[i, j - 1] && (matrixOfGlass[i - 1, j] || matrixOfGlass[i + 1, j]))
BreakAPoint (i, j);
if (matrixOfGlass[i, j + 1] && (matrixOfGlass[i - 1, j] || matrixOfGlass[i + 1, j]) && UnityEngine.Random.Range (0, 2) == 1)
BreakAPoint (i, j);
//Test2 (if all up dont have sides)
if (matrixOfGlass[i, j - 1] && matrixOfGlass[i - 1, j] && matrixOfGlass[i + 1, j]
&& matrixOfGlass[i, j + 1] == false && matrixOfGlass[i + 1, j + 1] && matrixOfGlass[i - 1, j + 1])
BreakAPoint (i, j);
BreakAPoint (i, j + 1);
  • Страница 1 из 1
  • 1
Поиск:
